Intermittent long starts
Old Aug 26, 2021 | 01:51 PM
Backporch73's Avatar
Default Intermittent long starts
Hello everyone,
I have a problem with intermittent long starts. 90% of the time I turn the key it starts right up, the other 10%, I turn the key the vehicle cranks and keeps cranking for several seconds even if I let go of the key until it barely starts up, knocking and sputtering. Then the engine comes to idle and everything seems fine.
It doesn't matter if the truck has sat all night or if I just shut it down 5 minutes ago.
Gas mileage is s*!t, but I attributed this to the 37-in tires and KMC rims. It's a 2009 H3T Alpha with 107k miles. I've cleaned the MAF sensor and assembly, replaced the spark plugs. Didn't seem to help any.
I have a new code as of yesterday p0442.
Any help will be appreciated thanks
Backporch
Old Aug 26, 2021 | 02:27 PM
hopefully it was not this one.https://www.copart.com/lot/32689481/...pha-az-phoenix a member here i think had bought it a while back from what i remember.
Old Aug 26, 2021 | 02:32 PM
No that was a totally different thing, I've been a member here for a while, had a H3 5cyl before I found this in Florida. You're talking about a salvage auction that happened, and people were talking about, different vehicle.
And I just realized I made my post in the wrong area....lol..
Old Aug 26, 2021 | 02:49 PM
Hey BP, what's happening!
Did you mean you cleaned the Throttle Body, or just the MAF? If you have not cleaned the MAF, do so but always use MAF cleaner and avoid any other solvents on that. Have you scanned it for any hidden codes?
I see you have been busy sprucing up that jewel.
Old Aug 26, 2021 | 02:51 PM
Oh, and I moved it over and left a redirect for over the weekend too.
Old Aug 26, 2021 | 07:33 PM
Originally Posted by Backporch73
Hello everyone,
Backporch
Fuel/Evap leak, use your sniffer, back/ front /side to side /under.
PIT4943D
Old Aug 26, 2021 | 09:49 PM
Yes sir, thank you! I basically moved everything I had on the H3 over to the H3T lol, and had to do another 1.25 inch body lift to fit the tires . The roof lights are Cab Over America, wireless ones, liking then so far After I got the Air Doc installed I cleaned both the MAF sensor and the Body, I have both kinds of cleaners. Then I did general maintenance/clean ups, brakes, fluids, shocks etc. I changed out the spark plugs before the Florida trip.
Hummerz feels it's a vacuum leak per the code so I'll start there, but do you think I should replace the MAF sensor as well?
Old Aug 26, 2021 | 09:50 PM
PIT4943D
Thank you sir I'll get on it, and thanks for the PDF
Old Aug 27, 2021 | 10:25 AM
if you unplug the MAF sensor and it runs better then it could be suspect. if not then probably a intake manifold gasket leak
Old Aug 27, 2021 | 04:52 PM
No>>> Evaporative Emission (EVAP) System Leak.
Symptoms of an EVAP Leak
Even before you run diagnostics, a few signs can indicate that your check engine light is the result of an EVAP leak rather than some other issue. A symptom such as the smell of gasoline is obvious, but these others can also crop up:
● Trouble starting the engine
● Bad fuel economy
● Rough idling
● Overall drop in engine performance
K0PIR
Oct 11, 2021 02:43 PM
REV99Z
Sep 3, 2017 09:38 AM
NFS
Jul 29, 2016 12:32 AM
dougie
May 13, 2016 11:04 PM
sakodik
Sep 29, 2013 11:20 PM
