HELP! engine starts and runs but dies when key released
Old Aug 20, 2017 | 02:54 PM
REV99Z's Avatar
Exclamation HELP! engine starts and runs but dies when key released
I have a 2007 h3 with the I5 3.7L. 188,000 miles and a fresh trans rebuild.
When I go to drive it, it starts and runs awesome but when you release the key from the crank position it does immediately reguardless of if your idling or reving.
I have deleted passkey/CATS through PCMs for less so it's not that. I've read some threads that say ignition switch but most people with these symptoms had no luck with that.
The big part of this is if I hold it forward I can drive a mile or two and release the key and it stays on no problem. It didn't happen all the time at first but now it's every time I go to drive it. I have no clue what's going on here. Any help?
Old Aug 20, 2017 | 07:02 PM
happythree's Avatar
study the wiring for run/crank info, relays.
it cranks but no run, something missing.
ill look when i can..
looks like ign sw cranks in start AND run positions, no sense there?
bcm,pcm is involved huh?
Old Aug 21, 2017 | 10:25 AM
RKSmith163's Avatar
Ignition Switch.
Old Aug 21, 2017 | 06:23 PM
Originally Posted by RKSmith163
Ignition Switch.
x2....
Old Aug 21, 2017 | 10:31 PM
Happy Hummer's Avatar
I'm go out on a limb here and say it or ask?
Did the H3 do this directly after the trans replacement?
Old Aug 26, 2017 | 06:37 PM
REV99Z's Avatar
No, it ran fine after the trans swap. It started a few weeks later and it was only every now and then. Now it's almost every time.
Im going to dive in this week and check the connections and wires to the ignition and double check my fuses and relays. If I find nothing then next weekend I'll buy a new ignition and switch it out.
Old Aug 26, 2017 | 06:41 PM
REV99Z's Avatar
I've also found if I start it while giving it gas so as to rev to about 3k rpm it most always runs Fine and I can release the key as it falls back to idle speed
Old Sep 1, 2017 | 06:52 AM
Your sure this is not a TB issue?
Old Sep 2, 2017 | 07:23 AM
REV99Z's Avatar
negative, I cleaned the mass, intake and TB up nicely about 2,000 miles before this.
Old Sep 3, 2017 | 09:33 AM
I'm referring to an internal computer error with the TB chip. From what I understand there is a computer connection to the TB that has to function correctly or you get all kinds of cr@p going on.
