H3T - N2M Storage Box - recoding lock?
Old Jul 18, 2020 | 12:54 PM
LW53's Avatar
Default H3T - N2M Storage Box - recoding lock?
Hello,
I have recently purchased a used OEM full width storage box for my T, however, I am unsure how to “code” my ignition key for the locks, as the locks were coded to the T from the owner I purchased the storage box from.
1. What is the process to recode the locks to my ignition key?
2. Is this something that I would drop off at my local dealership with the second key that they would do?
Cheers
Old Jul 18, 2020 | 10:55 PM
Echelon's Avatar
id try to get the lock assembly out and let a locksmith have a good look. leave him your spare key
Old Jul 20, 2020 | 12:11 PM
Locksmith and a key.
Old Jul 23, 2020 | 10:03 PM
LW53's Avatar
Update:
With enough playing around I ended up being able to use my ignition key to successfully open it with enough jostling and finding the “spot.” Considering the original owner had it coded to his keys, I find this a little bit problematic, considering what I thought would be a secure compartment is no longer that. I have also washed it and left it outside in a light rain to assess the water proofing. Unfortunately, the water proofing leaves a lot to be desired as water was managing to find its way to the bottom in a light shower. I guess my next project is figuring out where it’s leaking from and potentially remove and reinstall the rubber adhesive to waterproof it.
TLDR, I’m left with an OEM Hummer box that different GM keys can open, and leaks water.
Old Jul 24, 2020 | 07:25 AM
They all leaked. They where never waterproof or water tight. I had a few.
People use to seal them with silicone and taller rubber seals.
Old Jul 24, 2020 | 12:59 PM
You wouldn't find any of my tools in it. More like a party cooler, made in Canada.
HUMMER H3T Storage Box Product Showcase
Here's a quality tool box: CRAFTSMAN Matte Black Aluminum Crossover Truck Tool Box
Old Apr 16, 2021 | 10:45 AM
JaylenBrown's Avatar
Yes, getting a new spare key made by a locksmith is far better because you can use that spare key in an emergency.
jasperpops
May 14, 2024 10:19 AM
ericksos
Nov 7, 2022 06:02 PM
VICTORYREDH2
Jan 4, 2008 03:12 PM
