windshieldwasher
Old Aug 15, 2023 | 03:32 PM
mitch1856@485's Avatar
sorry i did not know i was not doing this the correct way it is a basic model and yes it has a sun roof but seeing as i just purchased this i have not tried the sun roof the battery terminals have been changed i was told that the passenger side floor was wet the passenger side power seat also has no power going to it . i got this to work on and dont know alot about them
Originally Posted by mitch1856@485
the one facing the front of the car the washer on the back works fine i did not know there were two on a 08
You tested the front(windshield washer) pump switch from the REAR pump connector on the reservoir?
Old Aug 15, 2023 | 08:01 PM
no my wife held the washer switch down with the key on and i tested the plug going into the front pump
Old Aug 15, 2023 | 08:39 PM
With your wife holding the front (windshield) washer switch, you need to check connector at the rear pump(on the reservoir).
Old Aug 15, 2023 | 08:46 PM
Or you could swap the lines where they enter the cowel(above the tank) and use the rear washer switch for the windshield.
Old Aug 16, 2023 | 07:39 AM
ski.dive's Avatar
Thumbs up
Great suggestion!!!​​​​​​​
Old Aug 16, 2023 | 07:51 AM
it is a 2008 hummer h3 basic. Yes it has a sun roof but i have not tried to open it. the battery terminals were changed. i was told that at one time that the passenger side was wet i also do not have power to the passenger seat but i do on the drivers side everything on the turn signal switch works except the front washer the back washer works fine
Old Aug 16, 2023 | 10:09 AM
It is not important whether the Sunroof has been opened or not. It is important that your passenger floor got wet. The BCM is mounted behind the Passenger side Kick Plate. Clogged Sunroof Drains allow water to overspill the Sunroof Tray and run down the A Pillar directly on the BCM and its connecting Harness. Gremlins galore are possible after that, including possessed or failed windshield wipers and washer pumps. Pop the Kick Plate and inspect the BCM and its connections for corrosion and clean with CRC electronics cleaner if corrosion is present (Battery disconnected until dry).
Do the fix ASAP. Finally, a fix for clogged sunroof drain tubes
Old Aug 16, 2023 | 11:53 AM
i assume i can diconnect all the plugs one at a time and clean them hate to be a pain thanks
Old Aug 16, 2023 | 01:44 PM
Sure. There are some other threads/posts on the BCM. There are some vids on line as well. Remove the plastic door sill first, then the kick plate.
Good luck
