Weird question
Old Jan 7, 2020 | 03:46 PM
The upward switches were a new design for the '08 model. Easy to check vin for production date. Maybe someone changed the panel in last 12yrs? If indeed oem, could have crossed model yrs? Check manufacturing dates:
Originally Posted by TAINTER
Incorrect information.​​​​​​​
I never stated that the panels could not be included in the late '07 model, while the '08 model was in production.
"In the United States, for regulation purposes (such as VIN numbering and EPA emissions certification), government authorities allow cars of a given model year to be sold starting on January 1 of the previous calendar year. For example, this means that a 2008 model year vehicle can legally go on sale on January 1, 2007."
Old Jan 7, 2020 | 04:15 PM
Yes, my early 2007 (built Nov. 06) had the low/flat mounted window & door controls, later 07s and from 08 on all have them mounted forward on an angle.
My '07 mounts flat too. '08 started production 3/07, while there were still '07's in production.
Old Jan 8, 2020 | 08:01 AM
hummerz, Keep back pedaling buddy!
PLEASE, Do a little reading/research from people/sources who know before you cut and paste from some chart from your "fix it" manual.
"The updated door panels are available on H3s that were built later than February 1st, 2007." - https://www.hummerguy.net/hummer-new...erior-slightly
Old Jan 9, 2020 | 05:47 PM
wpage's Avatar
The 2006 controls for windows were set too far back.
GM made the fix as soon as they could and this is not a wierd quest...
Old Jan 9, 2020 | 06:54 PM
Thanks for that, now I can sleep better at night. However, it does not change the fact that these panels were designed for the 2008 model(starting 01/07). I'm content with my switches flat, since I drive with my seat, adjusted farthermost to the rear. Fyi, Hummer was not designed for the vertically challenged.
Old Jan 10, 2020 | 01:01 PM
Man this is a weird thread.
Old Jan 11, 2020 | 09:21 PM
5GN-H3T's Avatar
A late door panel will not bolt up to an early door. The sheet metal is different. I've had both side by side. I've used late doors on an '06 with the '08 door harness and everything worked fine.
jayhawk714
Nov 13, 2014 04:16 PM
CurtisP87
Mar 27, 2014 08:10 AM
C31322
Dec 23, 2013 08:22 AM
wfturner
Oct 18, 2009 09:20 AM
heavyD
Apr 27, 2008 07:54 PM
