Transfer case issue
Old Jan 7, 2020 | 01:10 PM
James01973's Avatar
Default Transfer case issue
So I’m sure that someone has already answered this a million times. I have an 06, of course I had to crack the transfer case open and replace the fork. Is there a gasket between the two main half’s of the transfer case and if so does anyone have a part number. Thanks
Old Jan 7, 2020 | 01:20 PM
NO GASKET.
I always use Permatex 81180 Automatic Transmission RTV Sealant.
Since you are using Trans fluid in the T-case.
Replaced forks and chains on several. Never had a leak.
Permatex 81180 Automatic Transmission RTV Sealant Permatex 81180 Automatic Transmission RTV Sealant
Old Jan 7, 2020 | 01:25 PM
RTV is good stuff when used properly. Follow the instruction exactly where they state: "apply a continuous 1/16" to 1/4" (2 to 6mm) bead of silicone to one surface; surrounding all bolt holes. Finger tighten bolts until material begins to squeeze out and around flange. Allow to dry one hour then tighten to torque specifications. 4. Allow 24 hours to fully cure before filling with fluids and returning to service (allow more time to cure in cold or very dry conditions)".
If not, that is where you will have problems.
Old Jan 7, 2020 | 01:30 PM
James01973's Avatar
Awesome! Thanks so much!
bigstick0000
Sep 17, 2020 09:29 PM
charlie6017
Jun 11, 2019 12:22 PM
specialtariq@gmail.com
Jun 19, 2017 07:43 PM
ElGuapo
May 17, 2015 07:34 PM
man-of-war
Nov 5, 2013 06:22 PM
