Transfer case actuator positions
Old Mar 20, 2022 | 03:29 PM
Zco's Avatar
Zco
Default Transfer case actuator positions
Can anyone tell me what the clock positions are for the tcase actuator? I am going to change mine and want to make sure I am matching the correct mode with actuator position. Thanks.
Old Mar 20, 2022 | 04:47 PM
ONLY 1 way to install! Perhaps you need practice:
Old Mar 20, 2022 | 05:17 PM
Zco's Avatar
Zco
If I needed a lesson on how to get it in, I'd probably be at your house while you're at work.
Old Mar 20, 2022 | 06:40 PM
Old Mar 20, 2022 | 07:09 PM
Sam!'s Avatar
I can see needing some reassurance. I cycled the actuator un mounted and marked all the positions then cycled the t-case with vise grips to test the stops then installed and there is no way it can go on wrong. Only thing it will not do is fix a internal t-case problem.
JimDrew
Jun 8, 2024 03:23 AM
LatvjuAvs
Apr 17, 2019 11:31 AM
JakeH2
Jan 11, 2019 09:26 AM
DrtyR3d
Feb 26, 2014 03:25 PM
H3 PIlot
18
Aug 11, 2012 03:27 PM
