Tranny issue…
Old Jan 12, 2023 | 10:26 AM
Hummerhead's Avatar
Default Tranny issue…
I own a base model H3 with 150k miles. I have owned it since new and have had the transmission replaced and a top end rebuild about 30k miles ago.. I had a strange thing happen yesterday where I was driving and noticed slipping in drive, like the truck went into neutral. I tried manually shifting down but same symptoms. I pulled to the side of the road, placed it into park with the engine idling and inspected it for leaking oil…none. Checked the oil level…perfect. I got back into the truck put it into drive and to my surprise it operated perfectly again and I drove home. What in the world? Seems like I lost pressure and then it came back after sitting and idling. Anyone have any ideas? Oil pump? By pass valve thingy? Kinda afraid of driving it thinking I might get stranded.
Old Jan 12, 2023 | 02:41 PM
Was the Trans replaced with a new one, remanufactured, or rebuilt unit?
You stated you checked the oil level, did you check the Trans Fluid level and quality via the color & smell test?
Old Jan 13, 2023 | 02:32 PM
Hummerhead's Avatar
Thanks Doc Olds, Remanufactured. Oil has less than 5000 miles on it and is in good shape bright red no burnt smell.
Old Jan 27, 2023 | 03:28 AM
Shorty's Avatar
Did you check when the transmission fluid was hot, warm or cold? Make sure you you check on a level surface and against the correct level for the temperature. Had a similar experience with a new 4L60E where i needed to top the fluid up. The breather tube was also blocked causing incorrect fluid level readouts.
Johnny1950s
Dec 2, 2021 09:48 AM
ferraribuyer
Mar 27, 2017 09:04 AM
AR15wheeler
22
Sep 17, 2016 01:19 AM
JMGPhila
May 2, 2015 12:20 PM
yuflesh
Jan 22, 2011 11:12 AM
