Hummer H3For the Hummer driver who wants the rugged look and off road capabilities of the Hummer, but in a smaller size and with a more fuel economy friendly engine.
Good evening everyone. I have an issue with my 06 H3 A.T, it has 116k miles on it. I have replaced my battery terminal connectors, and just replaced my E.C.U. I still have the same issue, it's intermittent some times my truck will not start sometimes it starts first turn of the key. My traction control light comes on along with stably system battery and check engine and some times the P.A.S light is on. My truck won't crank or anything. When it does start the dash would light up with the above lights. The dials would die and the radio would go down in volume but not off. Everything still works apart from Cruze control. Any ideas, suggestions, Help!!! Thanks Terry
Disconnecting the battery on an H3 does nothing, it stores the last 300 ignition cycles power or no power. It can turn of certain CEL depending upon the trigger, but the code is still there and the CEL will illuminate as soon as the PCM re-discovers the fault.
What is a P.A.S light? Was that passlock?????
Have you tried cleaning the ignition switch with CRC? Pic courtesy of hummerz...
