09 H3 - FAILED SERVICE - STAB SYS - TRACTION Warning lights
Old Nov 2, 2019 | 01:32 PM
DATMTN's Avatar
Default 09 H3 - FAILED SERVICE - STAB SYS - TRACTION Warning lights
09 Hummer H3 - 124k miles. Getting the POWER REDUCTION - FAILED SERVICE - STAB SYS - TRACTION CONTROL warning lights. Put in brand new battery, new accelerator pedal assembly, checked all fuses and 12 spot and Transfer Case Control module keeps burning out. Got the following error codes from diagnostics. Any suggestions on what to address next esp work I can do before going to shop? Many thanks!
Old Nov 2, 2019 | 02:06 PM
clean the mass air flow sensor and check the intake for leaks. check your purge valve.
Old Nov 4, 2019 | 11:18 AM
Is your transfer case fuse (#12) blown?
Old Nov 6, 2019 | 08:37 AM
Ricardowelch's Avatar
Originally Posted by DATMTN
09 Hummer H3 - 124k miles. Getting the POWER REDUCTION - FAILED SERVICE - STAB SYS - TRACTION CONTROL warning lights. Put in brand new battery, new accelerator pedal assembly, checked all fuses and 12 spot and Transfer Case Control module keeps burning out. Mike Cross reviews why is my abs and traction control light on at #AutoGuysLand. You can visit this site for more info. Got the following error codes from diagnostics. Any suggestions on what to address next esp work I can do before going to shop? Many thanks!
I think the following link can help you. Just try to take a look at this.
https://www.hummerforums.com/forum/h...d-power-24202/
Old Nov 8, 2019 | 02:07 PM
When you put in the brand new battery: 1) was it fully charged .... off the shelf from auto parts does not mean it was fully charged as they can sit there for months, and 2) are you still using the OEM crappy Battery Terminal Connectors?
650Hawk
Jan 2, 2016 11:42 AM
mskarenbear
21
Jan 8, 2015 02:30 PM
H3 Brad
Apr 8, 2013 04:46 PM
rifsm1
Aug 21, 2012 02:10 PM
6spd04cobra
Jun 3, 2011 03:08 AM
