Towing The Alpha
Old Jul 4, 2020 | 10:53 AM
alpha08's Avatar
Default Towing The Alpha
I am thinking about buying a motor home and was wondering what I would need to do to the hummer to tow behind.
Old Jul 4, 2020 | 10:57 AM
Old Jul 5, 2020 | 09:36 AM
alpha08's Avatar
Thank you for the video. I already knew this and should have been more specific. Does the steering wheel need to be secured and can you use the shackles is the front or do I need to connect to the frame with the tow bar. This will be a new experience for me. want to spend a couple of years just touring the USA.
Old Jul 5, 2020 | 01:41 PM
Steering wheel secured? You plan on driving straight all the time? I would recommend you do a lot of research and make sure you don't buy some cheap harbor freight tow bar that's only rated at 5000 lbs. You can get many responses in an online forum, however you have to remember those that respond, won't lose a cent, if something happens during your tow. Don't go cheap, and make sure you get the proper equipment, including a tow bar rated at least 7,500lbs, (H3 gross weight 6,000lbs+ depending on your payload).
Here's a good place for you to start your research>>>>>>>> Parts Needed to Flat Tow a 2008 Hummer H3
Old Jul 6, 2020 | 02:27 PM
alpha08's Avatar
Thank you for your help. Yes I am new to this and that is why I was asking questions. Thank you for your help.
Old Jul 6, 2020 | 02:33 PM
GL. I'm impressed with the Demco Dominator. Check out the installation video> Demco Dominator
OFFSHORE GINGER
Nov 15, 2014 01:39 PM
H3Ray
Oct 13, 2014 01:18 PM
itgoes211
May 11, 2008 06:31 PM
itgoes211
Apr 28, 2008 05:34 PM
milkman
Nov 29, 2007 12:45 AM
