torque converter bolts
Old 10-05-2013, 04:53 PM
boman53's Avatar
Default torque converter bolts
I am working on my nieces 2008 H3 Hummer with 3.7L 5 cylinder. I know little about it and am replacing engine, I would like to know if any one knows how to remove torque converter bolts easily? Thanks
Old 04-04-2022, 01:44 PM
RandyJ2007's Avatar
it is a royal pain but can be done. There is a special tool or you have to rely on creativity. I just watched a YouTube video. The guy used an 18mm socket he had ground down to short enough to fit between the flex plate and block. Then, he ground the sides so an open end wrench could be used to turn the bolt(s). One comment said the bolts can be turned with a T-50 torx bit.
Old 04-04-2022, 03:12 PM
Welcome to HF. You have responded to a thread posted near NINE YEARS AGO to a guy that posted one and only one thread/post. Please avoid that, stick to the front of the board.
Thank you in advance.
READ: Old Threads/'Necro-Bumping'
badss98
06-22-2021 09:50 AM
ben1272
09-03-2020 07:22 PM
dwd58
08-04-2020 09:57 AM
BERULAKIDE
04-09-2014 03:50 AM
LEFTTA
06-06-2011 09:54 AM
Quick Reply: torque converter bolts
