timing chain tension
Old Jun 17, 2024 | 09:13 AM
Are you asking if it is OK tor turn the engine counter clockwise with the crank bolt? If so, it doesn't matter, the engine is a rotating assembly, rotate away.
You do not have to remove the Oil Pan to change the chain, just loosen the bolts to their last threads which lets the front of the Oil Pan lower 1/2" or so so you can get the oil pick up tube bolt out of the oil pump to remove that. Swap the chain, put the pump back, get the pick up tube bolt started and tighten to speck (look it up it is like 9 ft.lbs. = hand snug with small wrench). Torque the Oil Pan Bolts and that is done.
Good luck.
Old Jun 17, 2024 | 12:06 PM
NFS's Avatar
NFS
Good luck.
thank you I was just making sure because I heard if you turn it the opposite way you may mess up timing or skip teeth or mess up ur engine but I already got the pan out I just unscrewed the engine mount and lifted the engine up and that gave me clearance to get it out. Cleaned it and all and now putting everything back
Old Jun 18, 2024 | 10:46 AM
NFS's Avatar
NFS
Default Update
Took off the front timing cover and changed the chain, guides and tensioner. Took the oil pan and cleaned it . Resealed everything and installed it back . The head is closed and complete just got few things to install back like the exhaust manifold and intake and belt and all then I am gonna flush the coolant with distilled water few times and refill it . Pray it’s good to go
Old Jun 21, 2024 | 07:08 PM
NFS's Avatar
NFS
So the car runs fine but I had a small problem. I was test driving it around the neighborhood and I was on a turn and all the sudden I lost like throttle I press on the gas it’s like nothing and then the steering wheel lik got harder when trying to turn it . I turned off the car and then it back on and it ran fine but then when I was pulling on the drive way it like hesitated. What could be the problem?
Old Jun 21, 2024 | 07:41 PM
check the fuel pressure
Old Jun 22, 2024 | 07:48 AM
NFS's Avatar
NFS
fuel pressure is fine I am more thinking maybe vacuum leak or something have to do with the steering wheel pump maybe ? Or throttle body ?
Old Jun 22, 2024 | 07:17 PM
was the fuel pressure 50 psi?
Old Jun 22, 2024 | 09:05 PM
NFS's Avatar
NFS
While it’s running ?
Old Jun 23, 2024 | 12:20 PM
should always be around 50 psi. at idle or running. check your long term fuel trims.
amccoy
Jan 13, 2022 05:10 PM
frankp
Apr 17, 2019 01:44 PM
MeBelovinMyH3
Jul 14, 2014 11:02 AM
hangout
Sep 15, 2012 08:15 PM
bigdog100
Feb 22, 2012 12:52 PM
