06 H3 cold tick
Old Jul 14, 2014 | 09:52 AM
MeBelovinMyH3's Avatar
Default 06 H3 cold tick
Hey guys,
I have read couple of different forms on this and have no direct answer. The sound is a ticking.
I think it is in the top of the head. Like valve or rocker. It does it when cranking and running until warm. Just wondering if I should get it checked out or let it be. Sorta hard getting to a shop with it still cold. lol
What do y'all think.. I could possibly do a video on it.
Thanks!!
Old Jul 14, 2014 | 10:53 AM
From an old post of mine:
"The Atlas Series engine has hydraulically actuated timing chain tensioner that requires the oil pressure to first come up to add the required tension to the timing chain. Over time the chain will stretch, but the tensioner has ratches that will eventually allow it to click over to the next position to correct for the slack in the chain. Sort of like self adjusting brakes worked.
When you first start the cold engine, if the chain is loose and before the oil pressure can come up to take up the slack, the chain may contact the insides of the front cover. It sounds like a rattle that immediately goes away.
What is happening is the chain is loose enough to slap but not yet loose enough for the tensioner to click over to the next position. Not all will do this, but a bunch can for a while. If this persists for a long time, you may have a timing chain that stretched too far, or tensioners that are worn and need to be replaced.
GM TSB 06-06-01-017G covers the revised cylinder head and timing chain service procedures for these engines.
Many/most will tell you this is normal. I would say it is more expected than truly normal, but it is not a big deal IMHO. Life is good if this is all you are worried about.
My 07 hasn't done it.... yet. "
SEARCH timing chain tensioner.
Old Jul 14, 2014 | 11:02 AM
Thanks Doc!! I knew you would come to the rescue.
Little pic from V-day.. Most current one I have of ole hummy. Well as of now!
gr8hntr
Apr 24, 2014 09:09 PM
cigarlvr
Dec 21, 2007 07:19 PM
madmaxmyers
29
May 24, 2007 02:13 PM
Dennis
Jul 9, 2006 07:05 PM
usmcman001
24
Jul 2, 2006 06:03 PM
