Stumbles on cool start up
Old Aug 17, 2019 | 06:53 AM
  #21
Twisted sisal's Avatar
It will do it at anytime with a full tank of gas or a qrt tank I did a fuel pressure test I had 55lbs of pressure and my leak down test I lost 10lbs in 10min
Old Aug 28, 2019 | 08:35 AM
  #22
HumbleAg's Avatar
Have you performed an induction service?
I'm currently doing my annual service on mine right now, got the tank from penray rep(pic below). Add a 1/2 can of seafoam, adjust the flow( a slow drip) and run at 1800rpm until the tank empties. Seafoam also carries a spray can with a long hose attached that you can try:
Well, this seemed to work. Used the spray can and followed the video procedures. Still got quite a few misfires right afterwards, but drove around a bit and they stopped. Have cold started a couple of times since then and no misfires reported.I think that indicates it was a sticking valve issue, just need to see if it comes back. Since the Hummer isn't a daily driver, sitting up seems to cause it to misfire more.
Thanks for the help!
Old Sep 4, 2019 | 03:40 PM
  #23
I only average around 3k miles per year, however I only use top tier fuel, I also keep the oil clean with a quality full synthetic oil, and keep the air filter clean. If you ever experience a performance issue in the future, you now know where to start.
mt2ut1
Jan 1, 2017 10:07 PM
Gunfighter13
Jul 24, 2014 10:26 PM
KingJoseph
Jan 29, 2014 05:49 AM
KentuckyRock
May 16, 2013 07:47 PM
mt2ut1
Dec 19, 2010 09:02 PM
