Stumbles on cool start up
Old Jul 26, 2019 | 05:19 PM
Originally Posted by Twisted sisal
I've done all the checklist this thing couldn't be cleaner it has new plugs, coilpacks, MAF, injectors, new battery terminals, new cayts, new 02 sensor up and downstream. I'm at wits end
Keep throwing parts at it...
Here's some good reading for you:
(Page 1 & 2):
https://static.oemdtc.com/TechLink/TechLink2011Sep.pdf
pip3146d:
www.askatech.com/AskATechLive/forums/ResourceHandler.ashx?a=3311
What fuel to buy:
https://www.toptiergas.com/
File Type: pdf
Old Jul 28, 2019 | 06:57 PM
Twisted sisal's Avatar
My fuel pressure is 55 psi it does lose 1lb every min so I lost 10lbs in 10 min on leak down
Old Jul 28, 2019 | 07:11 PM
Do you smell fuel anytime parked/not running?
Old Jul 28, 2019 | 11:17 PM
It has no fuel smell but I'll try cranking without the cap but it's also new ...i left the old one at the gas station
Old Jul 30, 2019 | 11:23 AM
I tried the seafoam cleaner so far 2 cranks it hasn't stumbled thanks so much and fingers crossed
Old Jul 30, 2019 | 02:39 PM
As I stated above; Cheap Fix
Now you know what caused your issue. Only use top tier fuel, and if there is a performance issue: Decarbonize.
Old Aug 15, 2019 | 01:40 PM
The stumble came back just as bad I cleaned it several times with the top engine cleaner they work for few days
Old Aug 16, 2019 | 02:50 PM
Where are you fueling?
https://www.toptiergas.com/licensed-brands/
Old Aug 16, 2019 | 03:07 PM
have you noticed if it is happening at a certain fuel level maybe something is off with the sending unit in the pump or the fuel gauge is miss reporting the amount of fuel or the fuel pump pickup is disconnected or damaged.
Old Aug 16, 2019 | 06:14 PM
Good questions.
I always ask many questions to the customer before servicing their concern.
A problem here: post an issue and give limited information.
From the limited information I gathered, fuel contamination is the cause?
