So confused..
Old Dec 17, 2019 | 02:52 PM
Allen Barr's Avatar
Default So confused..
Ok so I have a 2008 H3 Hummer and my check engine light turned on...after having it had been diagnosed the p0411 code came up which is a Air Solenoid....My problem is that when driving my transmission keeps slipping out of gear. After shutting the truck down I can start back up and go some more...but this is a repetitive process..when pulling into my driveway I like to back in..but when shifting into reverse nothing happens until I shut the truck down then restart...Mechanics are all telling me it's my transmission and I can't be sure because I don't see a code.... and can't afford 2000 dollar's for something that may not even be the issue...please help..
Old Dec 17, 2019 | 03:30 PM
Originally Posted by Allen Barr
Mechanics are all telling me...
Are the Mechanics that are telling you, via 1-800, online, or hands on?
Old Dec 18, 2019 | 08:28 AM
MILES on the vehicle are important to know.
When was the last time your Trans fluid and filter were changed? Pull the dipstick, wipe it on a clean white paper towel or rag, what color is the fluid? Does it smell burnt?
You don't need a code to know it is time for a Trans rebuild. When it stops moving because it "is slipping out of gear" ought to be the first clue.
Your P0411 has nothing to do with your Trans.
Hummer Charlie
Mar 19, 2019 07:20 AM
Kknox
Mar 29, 2018 04:22 PM
H3help
Jul 6, 2015 12:56 PM
mperry10
Apr 10, 2013 11:34 AM
