Seat belt warning
Old Oct 28, 2019 | 07:25 PM
Bergie's Avatar
Default Seat belt warning
I have a Hummer H3 Today when my wife and son got in there was a seat belt illuminated with a red ball on the passenger All of our seat belts were clicked in
What does that sign mean?
Old Oct 28, 2019 | 10:51 PM
That's easy to diagnose, just let your wife know, she has to go.
Old Oct 30, 2019 | 01:53 PM
YEAR and MILES???????????
There is an issue with your inflatable restraint system (air bags). Could be a number of issues, some of which are more prevalent in certain year H3s than others.
Old Oct 30, 2019 | 03:22 PM
Bergie's Avatar
2007 H3 96500 miles
It was the air bag sensor passenger side It cleared for now
Old Oct 30, 2019 | 03:38 PM
Not correct, since the occupant module is working.
Old Oct 30, 2019 | 03:42 PM
Read your owner's manual. If you had a small person under 5' tall and less than 100#, the passenger front seat, the system recognizes that and turns OFF the passenger side front airbag.
You talking about this???? In the TC Button Controls bar?
Old Oct 30, 2019 | 05:06 PM
Bergie's Avatar
No on the panel to the left drivers side (This is the panel where the check engine lights appear seatbelts etc) The seatbelt light came on with the red ball in lap It did not clear with my wife in the passenger seat while driving
The next day I sat in the passenger seat and this light did not appear while parked
Will try again today when we take a ride and see if it re appears
Old Oct 31, 2019 | 10:44 AM
OK, yes you have an inflatable restraint system error. Could be just bad connections causing a glitch.... or a bad sensor, bag or module. 2006-07s seem to have more issues with the module and communications between it and the bags. I found this out after researching those issues more than I care to think about. In 2008+ they used a different module for the overhead side curtain capability.
Basically every time the truck is started, the system checks itself for proper voltage (sensor input) and communications, when something is not within specs the light comes on.
My 07 had that issue for years intermittently, almost always when it got below 55 degrees F. I checked all connections more than once. It would go away all summer, then come back in the fall. I reset the BCM several times and it would go away for a few days and then return. I scanned it and it was in the passenger side IRS (do not remember the code ... B00## passenger side front deployment loop........??). So I rechecked all the connections on that side and no joy. Finally went to the GM dealer and they tried to reprogram the module which would not communicate correctly or accept programming. Replaced the module under the center console, had it programmed and no more problems. In 12 years of ownership on that 07, that was the only thing it ever had to go to the dealer for.
You will need to get it scanned with a scanner capable of reading IRS to check for any codes and diagnose the problem if it returns. If you do, please post the code(s) here and let us know, maybe we can help further.
Old Oct 31, 2019 | 11:07 AM
Bergie's Avatar
Thank you so much I appreciate it very much
Old Oct 31, 2019 | 12:25 PM
Most common is B-$$$$
Shorty
Sep 25, 2018 10:26 PM
jorswift
Feb 29, 2008 04:54 PM
h3andme
Feb 26, 2008 08:18 AM
pcmommy
Feb 22, 2007 11:21 PM
Petracco
Feb 11, 2006 09:56 PM
