Relay
Old Aug 29, 2022 | 12:40 PM
cockneyrebel's Avatar
Question Relay
Hi guys my 2007 h3 has one indicator working at normal speed and the other side is twice as fast no bulbs are out so would this be the relay and if so where is it many thanks John.
Old Aug 30, 2022 | 08:37 AM
RVR's Avatar
RVR
First, check your battery and the terminal connections.
I was having weird intermittent electrical issues that turned out to be a cell periodically dropping out in a battery still under warranty. Among others, one issue was one of the turn signals flashing very fast. Seems the H3 system is sensitive to either lower than expected voltage or lower than expected amperage, and goes into a tizzy.
Old Aug 30, 2022 | 11:57 PM
Happy Hummer's Avatar
I'll suggest to go under the rear end nearest the bumper and check the wiring carefully as this is a know area of trouble. Mine was all corroded when I first got my Hummer H3 in 2011.
Tomahawk
Mar 6, 2018 01:13 PM
happythree
Apr 8, 2016 04:34 PM
parrip
Nov 2, 2015 10:29 AM
Vinny713
Jan 15, 2015 10:17 AM
LoJac963
Mar 19, 2014 04:45 PM
