brighter lighting
Old Apr 2, 2016 | 12:51 PM
happythree's Avatar
Default brighter lighting
just stumbled into this old trick that works for me with stock lights,6 yrs with same bulbs. fogs come on with headlights.
Old Apr 2, 2016 | 04:36 PM
rsc's Avatar
rsc
I don't drive as much at night any more, but I was just thinking of doing this last night on the way home.
Old Apr 6, 2016 | 12:42 AM
Mkawas's Avatar
Can you give a more detailed explanation? I really feel my H needs more light power
Old Apr 6, 2016 | 01:11 AM
happythree's Avatar
the diode turns on fog relay when headlights are on.
it makes a big difference. be careful not to damage relay sockets when adding diode. it gets squeesed by the relay pins as you reinstall the relays.
Old Apr 7, 2016 | 09:07 PM
norinco3264's Avatar
I have an 06 and I can turn on the fog lights while running the headlights. Is this normal? I didn't change anything in the lights wiring other than pulling the Daytime Running Lights fuse. However, when I turn on the brights, the fog lamps turn off.
Are you running the brights w/ fog lamps?
Old Apr 8, 2016 | 10:24 AM
happythree's Avatar
from my memory,5 yrs ago, fogs went out when heads came on, not sure.
now fogs come on with heads hi/lo.
look at wiring for a better picture.
Old Apr 8, 2016 | 01:29 PM
650Hawk's Avatar
Standard is that the fogs will work when the low beams are on, but not when high beams are on. The diode trick allows the fogs to stay on even when the high beams are on, although if I remember correctly, they will blink off momentarily during the transition from high/low and low/high.
Old Apr 8, 2016 | 02:19 PM
OK, so here is the big $64 question..... Radio Shack is out of business, where do I get that diode?
Old Apr 8, 2016 | 03:59 PM
Broken Halo's Avatar
Abel Electronics over in your neck of the woods Doc
Abel Electronics | Retail Store
F.Y.I. Radio Shack at Masonic & Gratiot has them in stock #2761102, or if you go to Abel, ask for a 1N4003 micro 1-amp diode.
(retirement bores me sometimes so I did the leg work for you)
Old Apr 8, 2016 | 04:34 PM
happythree's Avatar
its nothing special,any diode like 1 amp that will fit.
you want small wires so u dont distort the relay socket connectors.
any electronic parts store u can find, although they are vanishing, lots of mail order companies but shipping for one is a killer. find a ham radio guy or club, they all have tons of parts,,,i know!!
steveng
Jul 14, 2012 05:08 PM
Gunner_45
Nov 29, 2007 09:02 AM
triplej2k6
Sep 19, 2007 05:55 PM
cigarlvr
May 17, 2007 12:13 PM
bigbanana
Jun 9, 2006 06:47 PM
