rear door actuator replacement on 2006/H3
Old Jun 1, 2020 | 02:17 PM
2004H2's Avatar
Default rear door actuator replacement on 2006/H3
How do you remove and replace the rear tailgate Actuator ?
i cannot find any u-tube videos on it, it does not want to work and the R/R passenger door, do not want to work either.....
I have not called the hummer Dealer yet, i can just imagine what they want two fix both doors....
i bought a PDF, manual on it, it shows it, but it has no instructions on how to remove it.....
Suggestions....
thanks
Old Jun 1, 2020 | 04:00 PM
Endgate is simple. remove the entire panel, disconnect rod to handle, disconnect connector to lock actuator, remove 3- T-30 bolts on latch(door jam side), remove 1 bolt on inside.
Try clean/lube and check operation.
Pic looking from the access door panel.
hummer_on_fumes
Jun 6, 2019 06:48 AM
hummer_on_fumes
Nov 10, 2018 12:37 PM
CHP
Mar 5, 2013 06:18 PM
ingydrummer
Feb 19, 2012 09:38 AM
