Radio on but no sound
Old Mar 20, 2023 | 02:22 PM
Isaabeelm's Avatar
Default Radio on but no sound
I have checked the fuses, the cables on the radio (is the original one)
Please help!! 🙏
From time to time it starts to sound but as soon as I turn the hummer off and back on it does not work anymore
Hummer H3 2006
Old Mar 20, 2023 | 04:27 PM
Got an amp fuse #38?
Old Mar 20, 2023 | 04:32 PM
Isaabeelm's Avatar
Yes
Old Mar 20, 2023 | 04:58 PM
Did you check fuse/25amp?
Old Mar 20, 2023 | 05:03 PM
Isaabeelm's Avatar
Yes, it was working. I still put a new one when I was verifying the fuses that had to do with the radio.
Old Mar 20, 2023 | 05:22 PM
Check the amp/connectors/wiring. Look here:
Old Mar 22, 2023 | 02:58 PM
Are your speakers dead? The OEM speakers suck and get trashed in the doors from weather exposure. Might be time for a long overdue upgrade.
Happened to me with my 07, and many others. First one goes, then another & you still may not notice until it is like 2 on the same side, or both in the front etc...
Old Mar 22, 2023 | 04:00 PM
My 07 system is still oem. I drive above the speed limit with max volume. ALL speakers/sub/amp still working properly. All interior/exterior panels still vibrate with radio on max. Enough sound for me and the neighbors.
Old Mar 23, 2023 | 07:26 AM
Most likely all of your speakers are toast. Take off a door panel and test the speakers with a 9V battery to the terminals.
If it does not "burp" it's dead.
Old Mar 23, 2023 | 05:28 PM
Highly doubtful ALL 7 speakers failed. Radio signal is sent to the amp that feeds the speakers.
