Question about the compatibility of transfer case
Old Jul 17, 2021 | 11:27 AM
lifu's Avatar
Default Question about the compatibility of transfer case
Hi everyone, little question.
I have a 2009 Hummer H3 3.7L and it needs to be replaced with a transfer case. But I'm confused, some sites say that the 3.5L and 3.7L versions are all compatible? Can I use the 3.5L version? Thank you!
Old Jul 19, 2021 | 10:24 AM
You can easily use any year H3 T Case for any year H3. You have to pay attention to whether you have the BW 4493 (2.64 low range ratio) vs BW 4494 (4.1 low range ratio - rock crawler) assuming you want to put the same one back in. All years use either the 4493 or 4494 depending upon model.
Old Jul 19, 2021 | 10:39 AM
lifu's Avatar
Great thanks for your reply, my last model is 4493, can I buy a 4494 model TC for it? I found a seller on eBay : https://www.ebay.ca/itm/304068853825...2Cchnl%3Dmkcid
Old Jul 19, 2021 | 01:19 PM
lifu's Avatar
Default 5.3L for 3.7L original?
Simple question: My transfer case needs to be replaced. My last one was a 4493 NR4 version, which was installed on my hummer h3 2009 3.7L base sport. And my local dealer has a 2009 5.3L, NR6 T/C. Will it work on my 3.7L NR4 hummer?
Old Jul 19, 2021 | 01:45 PM
I know someone who swapped in a 4494 for a 4493 without issue, though technically from the factory the different T Cases also come with different Transfer Case Control Modules.
Old Jul 19, 2021 | 02:38 PM
Old Jul 20, 2021 | 08:09 AM
Scarlet620's Avatar
I just recently replaced mine from this website,
They guarantee it will fit, https://affordablepowertrain.com/
Fondo
Jan 25, 2020 02:40 PM
HUMVEE_H3
Aug 6, 2018 12:49 PM
thorg113
Mar 27, 2018 08:54 PM
Donnie6983
Nov 19, 2017 12:11 AM
deleaur
Dec 21, 2009 12:54 PM
