Blown transfer case 07 h3
Old Jan 12, 2020 | 05:07 PM
Fondo's Avatar
Default Blown transfer case 07 h3
I am also a noob. I recently blew my transfer case. I've been looking for replacements as my original has a hole in it so I need a whole new unit. I was curious if you could transfer a case from a 2007 Colorado to a 2007 H3 adventure package? Question 2 is what is the difference between NR4 option and NR6 option?
The Colorado case is by far cheaper then the H3 case. The Colorado T case I found was priced at $180 no option listed. The h3 Tcase NR4 option for $800 and the NR6 option is $1100.
Old Jan 13, 2020 | 08:27 AM
NR6 or NR4 ONLY for the H3.
BORG WARNER /4494 NR6 - Adventure/OFFROAD transfer case 4.03:1 low range ratio
BORG WARNER 4493 NR4 - Standard transfer case 2.64:1 low range ratio
If you don't do any rock crawling/wheeling get the NR4 (BG4493), they are more plentiful and cheaper.
Old Jan 13, 2020 | 10:04 AM
Your adventure package has the lower gear ratio T Case. Stick with that.
Old Jan 14, 2020 | 10:41 AM
Fondo's Avatar
Default Thanks
Thanks Doc and Tainter. I went to the stealer and got build sheet to determine the correct tcase. Build says NR4 and thats what is going back into the truck. Thanks for advice all.
Old Jan 19, 2020 | 09:04 PM
Fondo's Avatar
Another question. Without having removed is there a way to get part number from another source on truck? I have no location as yet to put Ol Whitey to pull part. I'm thinking I can remove splates and pull unit myself rather then go to shop or dealer. Its winter here so need shelter for this, lol.
Old Jan 19, 2020 | 10:14 PM
Old Jan 21, 2020 | 09:57 AM
NO idea what the heck you are asking in your 1st question.
T-case can be R&R'd in a garage with 2 strong people and simple tools as long as no broken bolts due to rust show up to play...
Old Jan 22, 2020 | 11:38 AM
650Hawk's Avatar
Just to clarify; if your build sheet says NR4, then your H3 does not have the Adventure package.
Old Jan 24, 2020 | 08:23 PM
Fondo's Avatar
build sheet and vin all state "Adventure package" as well as states NR4 transfer case. Please state your reasoning it can't, lol.
Old Jan 24, 2020 | 09:58 PM
Open glove box, look down on the right, outside of the pocket, and you will find a label titled "SERVICE PARTS IDENTIFICATION DO NOT REMOVE"
Once you find it, you will see the RPO codes.
The Adventure Package will include ALL of the following:
G94
ZM6
NZZ
NR6
QLB
XLB
YLB
ZLB
A pic of mine:
