Engine shuts off when slowing down or idle or turning
Old Jul 20, 2021 | 07:31 AM
MikeG239's Avatar
Default Engine shuts off when slowing down or idle or turning
My 2007 H3X has 144k and 2 weeks ago I started the car left my apartment and about 2 minutes into driving and as I’m completing a turn at a light the car slows down and it appears as if the engine shut off as I’m turning/driving. No steering or gas pedal. The emergency lights automatically came on. The electronics kept running but I was at a stand still in the middle of the road for a few seconds I put the car in park and turned it off turned it back on without any problem. It’s happend 3 times in that same way at the EXACT same spot at that light which is very odd. I only know some of the basics with cars. Google says it could be ignition cylinder fuel filter or alternator. Alternator and battery are fairly new. I’ve also heard check ground cable.
Old Jul 20, 2021 | 08:14 AM
Are you still using the OEM Crappy Azzed Battery Terminal Connectors??????? #1 thing to be replaced on every H3/H3T, they cause a variety of electrical issues. I have posted that here a ton of times, search out the threads if you want.
Clean the contacts of your ignition switch. There are recent threads on that too. Pass lock security system
Thatsgr8
Apr 24, 2021 05:56 AM
NFS
Dec 15, 2018 06:48 AM
FLH378
Aug 16, 2010 11:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
mslilly
Jan 9, 2008 10:41 AM
