Weird engine noise!?
Old Nov 19, 2018 | 12:57 AM
NFS's Avatar
NFS
Default Weird engine noise!?
Hey guys, I been trying to figure out this issue but I had no luck yet when I drive the car in slow speed and the car actually moving I hear like small knocking sounds coming from the engine , even if the park is on park and I rev the car and keep it at certain level let’s say keep it at 3000
i heat the knocing sound, the car have new build and I thought it was the altenator so I installed new one, changed the oil checked everything and everything seems ok, the car drives fine and no check engine light yet it make that sound! 2007 hummer h3. Please someone help me figure out what it might be ?
Old Nov 19, 2018 | 08:35 AM
I do not know what your noise is, but revving to 3000 rpm is not going to fix it for sure.
How many miles on the engine?
Old Nov 19, 2018 | 09:10 AM
NFS's Avatar
NFS
I don’t just rev I was reving to diagnose the problem not just reving. Cus I wasn’t sure if it’s engine sound or drive related as when the car moving since when you drive and go little faster it merges with the engine sound and kinda fade but if I am driving slowly or on park and rev you can hear
it very clearly, the hummer have 130k on it
Old Nov 19, 2018 | 11:05 AM
Happy Hummer's Avatar
Is this the original engine or rebuilt / replacement?
There are literally dozens of possible diagnose. Without further insight it's going to be tuff give the correct information.
Old Nov 19, 2018 | 12:16 PM
NFS's Avatar
NFS
its the original engine. I can see if I can record it and upload it here to give you more insight
Old Nov 26, 2018 | 01:19 PM
NFS's Avatar
NFS
sorry for the delay, here is sound clip of the weird noise.
File Type: mp3
Old Dec 14, 2018 | 12:32 PM
NFS's Avatar
NFS
Anyone??? Have any ideas?
Old Dec 14, 2018 | 09:18 PM
Sound file didn't work for me.
Old Dec 14, 2018 | 11:08 PM
NFS's Avatar
NFS
I don’t know why it wouldn’t it’s mp3, can I email it to you cus attachment here is weird
Old Dec 15, 2018 | 06:48 AM
DJB's Avatar
DJB
Sound file plays for me but is just a bunch of background noise. You've probably spent more on the alternator than you would pay for professional diagnosis. Having said that - my first step is to remove the drive belt and run the engine without it for a moment (not TOO long as the water pump isn't turning). That eliminates the alternator, water pump, etc. as possible culprits. I've even found cracked accessory drive brackets creating a rattle that you would swear were internal engine noises! Another possibility is a cracked flywheel. Holding the brake in drive and applying some throttle without allowing the vehicle to move (power braking) will load the flywheel - if the noise goes away it's possible that the flywheel is cracked or the torque convertor bolts are loose (very possible if the transmission was recently removed and reinstalled). If you're running the I5 it's possible that it's time for a new timing chain and guides. And don't overlook the balance chain and guide in the back of the engine block. I recently replaced mine due to a buzzing sound. Keep in mind that's it's not easy for anyone to diagnose engine noises without hearing them as one man's knocking sound is another man's tapping sound - or clicking. Or buzzing. Listen to the sound file again and rerecord if needed. It would certainly help us help you.
Brian McGuire
Nov 8, 2019 08:03 AM
Cashville
Dec 6, 2013 06:56 AM
dudley
Oct 29, 2008 07:12 PM
mfish
Apr 21, 2008 11:01 PM
Willy
Jan 29, 2008 03:46 AM
