Question about 33” “skinny” tires.
Old Oct 6, 2023 | 04:02 AM
Azrael23's Avatar
Default Question about 33” “skinny” tires.
Hi i had question i searched and couldn’t really find the answer to. I own a 2008 Hummer H3 Alpha, I had a flat tire and had to replace it with a used tire, same size but different amount of tread and brand, will that affect the 4wd system? I was planning on trying to get new tires anyways in february. Just saving . Was wanting 285/75/16
I came across a ad for a set of 4 used tires, but same brand and tread, but the size was 255/88/16. The guy said they are 33in just like the 285:75/16 but skinny. Has anyone ever used these on a H3? Will they fit? Thank you for any input.
Old Oct 6, 2023 | 09:39 AM
Brand is important information to your question as different brands may actually be different diameter and tread width even though using the same 255/88/16. They should fit, but will look goofy.
The question is why? Why go to some old off size just to put used tires on your truck thinking you are saving a buck?
Good luck with that.
Old Oct 9, 2023 | 08:53 AM
Happy Hummer's Avatar
255/80 R16 :
Diameter inches (mm) 32.06 (814.4)
Width inches (mm) 10.04 (255)
Circum. inches (mm) 100.73 (2558.51)
Sidewall Height inches (mm) 8.03 (204)
Revolutions per mile (km) 629.02 (390.85)
285/75 R16 :
32.83 (833.9)
11.22 (285)
103.14 (2619.77)
8.42 (213.75)
614.31 (381.71)
Old Oct 9, 2023 | 08:55 AM
As can be seen the tires are pretty close in dimensions. If there priced right you could run em.
CurtisP87
Nov 16, 2015 06:57 PM
11zip
May 11, 2013 04:19 PM
Fireguywalters
Dec 4, 2012 03:45 PM
myfirstH3
Sep 19, 2009 10:25 AM
korn00
20
Jan 10, 2008 09:20 PM
