Purge Valve R/R Tip's
Old Sep 3, 2022 | 12:04 PM
Bryan Burkhalter's Avatar
Default Purge Valve R/R Tip's
Just replaced this morning and wanted to leave a couple of notes for the next person who may tackle this. First, absolutely take the 10mm bolt out first to release the bracket from the block. This gives you the needed ability to move the valve around to work on the clips. (in my head it makes more sense to leave it bolted up so it's stable while I work on the clips, but I couldn't access the clips) With the limited space to work with to remove this part, I ended up making my own version of a clip removal tool. Essentially I used a 6" landscape fabric stake (see pics) and filed the ends down a bit. It's worth noting that the ends were not at the same length, I had 1 about 1/8" - 1/4" or so longer than the other. This allowed to be able to wedge one side in first, then the other. With a bit of gentle maneuvering, I was able to fully back the clip out without it breaking. Also worth noting is that it may take quite a bit of effort to pull the connector off on each end afterwards. Lastly, it's worth it to have some new retainer clips on hand for re-installing the plastic wheel well liner. Even with the right tools, I broke a number of them, likely due to the age and them never having been removed before.
Related thread: Step by step purge valve replacement - Hummer Forums - Enthusiast Forum for Hummer Owners
Reason for new thread: READ: Old Threads/'Necro-Bumping' - Hummer Forums - Enthusiast Forum for Hummer Owners
v/r
Bryan B.
Old Sep 4, 2022 | 05:02 PM
Justinh's Avatar
Thanks for the post.
The push-pin retainer clips are Dorman 961-358D. I had to buy one today. They are too expensive at the local store to buy more than a few.
Old Sep 4, 2022 | 07:01 PM
push-type clip a20991 for chevrolet for gm 11589292
Old Sep 5, 2022 | 08:55 AM
Just wanted to be clear about what I used the landscape stake-o-matic' to remove. It was specifically for the connection on the right side of the valve in the picture below (see red arrow). With the responses being about part numbers for the wheel well liner retainer clips, I was afraid I miscommunicated what the stake-o-matic' was for!
v/r
Bryan B.
Old Sep 5, 2022 | 07:39 PM
Originally Posted by Bryan Burkhalter
With the responses being about part numbers for the wheel well liner retainer clips, Bryan B.
ICYMI? Retainer clips are around 8¢ each here: push-type clip a20991 for chevrolet for gm 11589292
Yet, go to a part store and pay around $3 each. CLIPS ARE OLD WEATHERED DRIED OUT, STOCK UP!
win717
Mar 21, 2022 03:10 PM
egroegart
Dec 30, 2021 08:56 AM
Alex DjFlaco
May 25, 2021 10:49 PM
rwdr
Feb 16, 2011 09:29 AM
