t- case rear output seal leak
Old Sep 5, 2022 | 10:25 PM
Germano's Avatar
Default t- case rear output seal leak
2008 H3 Alpha...
Hello. I recently developed a bad vibration while driving at highway speed and noticed oil residue covering the back of the vehicle. Upon inspection, the U joint on the yoke needed replacement. The oil spray came from the rear output shaft seal. (I also inspected the yoke itself. no hole in it)
I replaced the U joint and the seal and the ride is smooth again. The problem is that the transfer case is still leaking from the same location.
Did I miss something? Did I damage t case?
I'm losing about a 1/2 Liter an hour when in motion. It doesn't leak when stationary.
Thanks in advance
Sirina2
May 5, 2019 06:51 PM
Paranormal
May 3, 2016 06:15 PM
smileynialley
Mar 25, 2013 05:19 PM
rhino boy
Jan 12, 2010 09:11 PM
paulmar
May 3, 2009 11:05 PM
