H1 Transfer Case Leak
Old May 3, 2009 | 11:38 AM
paulmar's Avatar
Default H1 Transfer Case Leak
I have 2001 H1. I recently noticed a minute transfer case leak. Small dripping. Any opinions? Is it serious? How difficult to fix?
Do you know good mechanics in WA state?
PM
Old May 3, 2009 | 08:55 PM
phazer42's Avatar
where is it leaking from? If you haven't taken a t-case apart before, it might be a little overwhelming, but its do-able.
The t-case can leak from the outpus seal (where the driveshaft slides in), the spot between the t-case and the transmission, the t-case halves (between the front and rear case halves and the front output seal where the front driveshaft hooks up.
The front and rear driveshaft seals can be replaced without removing the t-case. The other two need the t-case removed, and the one requires dissasembly of the t-case to fix.....
as far as a good mechanic, any good certified ASE mechanic shouldn't have any issues with working on your tcase, nothing special....
Old May 3, 2009 | 11:05 PM
paulmar's Avatar
Thanks a lot for your help.
Paul
ride450
Jun 26, 2021 02:00 PM
hudson4269
Mar 7, 2017 09:12 AM
bigstick0000
Sep 12, 2012 08:13 AM
rhino boy
Jan 12, 2010 09:11 PM
Jul 19, 2006 03:05 PM
