Power steering high pressure pin
Old Feb 17, 2014 | 06:30 PM
soonermaniac's Avatar
Default Power steering high pressure pin
Hey community. I tried to replace my power steering pump today and the spring shot the pin out of the high pressure hose inlet and I don't know which way it goes back in. I can't find any diagram. It has a filter-looking end and a pin end. I know the spring goes in first but what end of that pin goes in first?
Thanks for any help!
Old Feb 17, 2014 | 08:31 PM
I figured this one out. You put the pressure pin in so the pin is coming through the coupling. That was a big mistake. Ugh!
Old Feb 18, 2014 | 08:46 AM
happythree's Avatar
anytime you are "lucky" to see a problem like that its nice to grab some pix. anytime I take apart anything I take a dozrn for reference layer. its nice that digital pix are free.
Old Jun 13, 2024 | 12:30 AM
mudking's Avatar
Default Spring and pin
So I had this happen to me as I was chaning the hi pressure line and had to remove large coupler that threads into the pump, I think it was like 21 mm as it was stuck to the 15 mm inlet for the hose .
but this pin and spring fell out. Thought i put it back right but no power steering at all when i put it back together. I put the pin in first with the flat head and the little filter end on the bottom then the spring and then the big bolt coupler.
i saw this post bupost a little confused still on the order
Any help is great
Old Jun 13, 2024 | 09:52 AM
So you dug up this 10 Year OLD Thread to tack on your question???? What irreplaceable information does this OLD Dawg of a Thread have that must be seen to help???? READ: Old Threads/'Necro-Bumping'
Next time, just ask your question in a New Thread and skip the Necro-Bump.
Old Jun 13, 2024 | 12:04 PM
Coronetkevin
Jul 1, 2023 02:04 PM
JimmyJack
Jan 19, 2023 04:25 AM
AdelRh2
Jan 3, 2019 01:22 PM
dontheo55
Jul 22, 2017 11:45 AM
Jackie Hicks Jones
Dec 18, 2012 07:16 PM
