Oil sucking out PCV ?
Old Jan 11, 2021 | 11:10 AM
  #21
Originally Posted by gwarrend
Thanks Hummerz. Can you provide more specific details?
Are you talking about the tube from the valve cover to the airbox on top? Or an exhaust resonator? My H3 has a muffler delete in case that helps.
The resonator is #1 at the top. Check #3 to the intake manifold.
Old Jan 11, 2021 | 06:28 PM
  #22
Yes that's the resonator. Crankcase ventilation needs air flow, to prevent excessive vacuum pressure=oil loss.
Old Feb 25, 2021 | 08:00 PM
  #23
gwarrend's Avatar
Closing the loop on this. I was able to find a used valve cover. Swapped it and oil sucking problem solved. Thanks all.
Old Feb 26, 2021 | 09:08 AM
  #24
Thank you for following up to the successful conclusion so this thread has the answer. KUDOS!
Justinh
Jan 7, 2022 12:48 PM
Maxine Rennspies
Mar 4, 2020 12:55 PM
Hmmm...er
Nov 12, 2016 01:11 PM
jemche
Mar 21, 2011 09:04 PM
