Oil Catch Pan
Old Feb 19, 2024 | 11:40 AM
Originally Posted by Justinh
How does an oil catch can (or pan!) help with keeping the intake valve clean?
With a DI engine and catch can you are not introducing the oil vapors into the air induction system via the crank case breather line (stupid emissions sheet).
In the DI engine the fuel does NOT wash over the back of the valve cleaning those oil deposits like a port injected engine.
Old Feb 25, 2024 | 05:56 PM
wpage's Avatar
With the Cross bar that runs across the frame. The oil change splash is significant...
So a good diameter catch pan is needed to prevent spillage. Your floor will thank you for good coverage.
Old Feb 26, 2024 | 10:50 AM
This post was about oil catch CANS. Explained if you read the entire thread.
Old Feb 26, 2024 | 12:01 PM
650Hawk's Avatar
A Fumoto oil drain plug eliminates that problem, but as Tainter said, this post was about oil catch cans, not oil drain pans.
Old Feb 27, 2024 | 03:55 PM
We have Fumoto drain valves on everything! All trucks, cars, tractor, generator, etc.
Old Mar 5, 2024 | 11:44 AM
wpage's Avatar
Thanks for the tip the F-137 looks like a good bet.
Old Mar 6, 2024 | 11:11 AM
F137N, the N is for the nipple. You attach a clear tube to the nipple end and the other end of the tube into your oil drain pan.
F137N
https://www.fumotousa.com/f137n.html
Old Mar 6, 2024 | 03:27 PM
Justinh's Avatar
I prefer the Stalhbus.
Old Mar 6, 2024 | 04:05 PM
"sic">>> Stahlbus
Old Mar 6, 2024 | 06:03 PM
wpage's Avatar
Why>?
