Noise and looseness from the fan/water pump pulley. Help
Old Sep 11, 2012 | 10:37 AM
kirkthms's Avatar
Alright will do! Thanks a lot.
Old Dec 24, 2013 | 04:15 PM
kirkthms's Avatar
I still have the rattling noise in my engine compartment I think it may be coming from the AC compressor, AC works great but when I had everything broke apart and inspected all the pulleys I would give it a good turn and would here some grinding coming from it, any chance that's where the noise could be coming from? if so how labor intensive is it to change. I'm a firefighter don't have a lot of free time. thanks for your help!
Old Dec 24, 2013 | 04:37 PM
Ever hear of a mechanics stethoscope?
Mechanic's Stethoscope
start vehicle and touch "non moving parts" find where the noise is the LOUDEST... there's your problem... GL
Old Dec 25, 2013 | 08:14 AM
Big Mike1's Avatar
I'm having a noise issue also which I think is the water pump.....Its at the dealer now and is their problem I'm still under the NYS 60 day used car warranty...
Old Dec 25, 2013 | 09:34 AM
kirkthms's Avatar
I used a stethoscope, the noise is definitely the AC compressor my question is; can I buy just the AC clutch or do I have to buy the whole compressor? Thanks for all the help!
Old Dec 25, 2013 | 10:20 AM
Big Mike1's Avatar
Looks like you can get the clutch seperate if I'm understanding this correctly..
Old Dec 25, 2013 | 10:21 AM
Big Mike1's Avatar
CLUTCH KIT. AIR CONDITIONING (A/C) Compressor Clutch. A/C COMPRESSOR ASM. # 15268655, 15-40042, 1540042
Old Dec 28, 2013 | 09:29 PM
Hummer99's Avatar
Normally you can buy the clutch only. Do some research though many times you can find the compressor with it for 40-50 bucks more. Then u have the choice to use the clutch only now and still have the compressor for when it goes...Or do it all at once your choice..If the the clutch is 50% or less the cost of a complete unit, just do the clutch id say, and don't open up the a/c system unless you have the right tools...most of us don't since laws and gases have changes..recovery unit, vacumn, gauges etc..
Good luck..Wish I would have saw this post before tonight, may have helped more..
hummer 99
07H3driver
Nov 24, 2014 01:30 PM
Johnny B. Epic
Feb 22, 2012 06:42 PM
williecee
Dec 13, 2011 03:19 PM
1st07Hummer
Jun 6, 2011 10:57 PM
2L8IWON
Feb 15, 2009 08:18 AM
