Noise and looseness from the fan/water pump pulley. Help
Old Jul 23, 2012 | 12:21 PM
R1guy777's Avatar
Default Noise and looseness from the fan/water pump pulley. Help
Hi guys,
My H3 is making a noise coming from the drive belt, fan, or water pump pulley. There is also some looseness in the fan, so I'm thinking the water pump needs replacement. Question 1> Do I need to replace the pulley when replacing the water pump? Do I need to replace the drive belt to eliminate the noise as well? anyone having the same issues with the H3? Thanks
Old Jul 23, 2012 | 03:01 PM
The pulley should not need to be replaced. It can be removed pretty easy and quick with a fan clutch wrench you can rent from a parts store chain for free.
to drain the radiator you remove the lower hose and drain it into a bucket. Round hose clamp pliers make that fast and easy as well.
Belts are about $30.00, you can swap out the pump and then see if the belt is noise free. Inspect the belt in case it has been slipping a lot or got chewed up.
Old Jul 24, 2012 | 03:54 AM
R1guy777's Avatar
Thank you Doc, I have ordered a new pump and a new belt already. You think is necessary to replace the fan clutch as well? Thanks
Old Jul 24, 2012 | 09:58 AM
I have run across a bad fan clutch, it was on a '71 Vette a few years back, but any part can potentially go bad.
If you did not have any temp issues before the water pump breaking down, and you don't think the fan was running all the time (you can definitely hear it), then I would not mess with replacing the fan clutch. You do have to remove it to get to the pulley so give it a good inspection once it is off.
Now, if it were me, I would be installing a PCMforless Efan conversion while you have it all apart up front anyway.
Old Jul 24, 2012 | 10:11 AM
mthoodh3's Avatar
your belt might have coolant on it which would cause it to make noise as well. you might be able to clean and adjust it to make it go away.
I have the same thing going on as well and it didn't occur till the dealership swapped out my radiator and water pump. i had coolant all over the area from the cracked rad which they probably half assed cleaned up.
Old Jul 25, 2012 | 10:38 AM
R1guy777's Avatar
A pcmforless conversion? Tell me more about that...please.
Old Jul 25, 2012 | 10:48 AM
R1guy777's Avatar
Never mind doc, I just did a quick research on that topic. Thanks
Old Jul 27, 2012 | 07:34 PM
2wheelmonster's Avatar
I've seen the conversion for the fan, it is a pretty cool setup
Old Sep 9, 2012 | 06:51 PM
kirkthms's Avatar
I am having the same exact problem, mine occured after mudding one weekend I have replaced bother idler pulleys, fan clutch and the alternater. I am doing the water pump next, everything from the idler pulleys down in the motor compartment was under water any idea what else could be causing all the rattleing?
Old Sep 10, 2012 | 02:36 PM
R1guy777's Avatar
you have to replace your water pump brother, and problem solved.
