no crank no start electrical issue
Old Sep 28, 2021 | 09:27 PM
tegriddy's Avatar
Default no crank no start electrical issue
Have an 06 H3 im getting nothing but check light when key is on have verfied all fuses replaced ignition switch entire fuse box underhood pcm battery and terminals no change ignition switch was causing a small drain that stopped after replacement however didnt change the no start i have power to most things the radio doesnt come on when key is turned to accessory im at a loss please assist
Old Sep 29, 2021 | 10:44 AM
Are you still trying to use the Crappy Azzed OEM Battery Terminal Connectors? If so, hack that chit off and replace with a quality aftermarket set like Stingers or your favorite brand.
What is the resting voltage of your battery? Is the passlock light on?
Old Sep 30, 2021 | 02:31 PM
tegriddy's Avatar
Default terminals
First thing I did was replace those for good ones i did have a dropping voltage changed out the ignition switch that stopped now i sit around 13.5 the passlock light is not on. When i put in and turn the key the only thing that happens is the check engine light no cluster radio etc
Old Sep 30, 2021 | 03:08 PM
Did you do/have any work done just prior to this happening? Anybody take apart the fuse block from the fuse box tray?
Old Sep 30, 2021 | 11:53 PM
Happy Hummer's Avatar
OK lol, let's back this up to the beginning....
What were the initial symptoms?
We're there codes?
What was your reasoning for each of the replaced items?
Because a car takes three things....
Air
Spark
Fuel
So if you are tracking a fault in the ignition you need to verify certain parameters.
You need to make absolutely certain you have solid clean grounds and +12v.
No other things.
Each ground removed, cleaned and continuity tested.
+12v main harness to starter removed cleaned and tested for continuity.
The starter would be tested.
The ignition switch and fuse box are not even in this early test faze. Because the starter should be able to turn without the switch or fuse box.
DanH3
Mar 14, 2023 08:38 PM
bureau13
Dec 22, 2019 10:25 AM
Douglas369
Oct 31, 2019 06:42 AM
emetdw
Aug 29, 2017 12:55 PM
wpduffey
Jan 3, 2015 04:43 PM
