New Guy Question and Tips
Old Dec 12, 2022 | 02:47 PM
CharlieTuna's Avatar
Default New Guy Question and Tips
Hey all. As the post implies, I'm looking to buy a Hummer H3 as something that I could work on (note: not too extensively) with my teenage son (never too young to learn). I finally test drove one this weekend and was quite impressed at how well it drove for its age. Wow did GM ever give up way too early on these!
Anyway, are there any particular items to look for that may get us in deeper $$$ than we imagine? The one I test drove did have a sunroof leak leaving the floorboard soaked, so I'd imagine there may be concerns with electrical there? Have also seen here that battery terminals need replacement. Other common issues?
Old Dec 14, 2022 | 10:15 AM
Welcome to HF. Do more reading before you post anything as you absolutely started a new thread in the WRONG Section. If you did that you would have seen: "Please DO NOT POST IN THIS SECTION just because you thought up some question!!!!!! This includes all you newbs."
As this is stuck near the top of the FAQs. Do not post in this section
With that out of the way......... I would not purchase an H3 with a leaking Sunroof. If you buy one with a Sunroof that you believe is not leaking then you need: Finally, a fix for clogged sunroof drain tubes
Do the Sunroof fix followed by replacing the crappy OEM Battery Terminal Connectors. Change out all the fluids, Trans & filter, T Case, front & rear diffs.
H3s also suffer from leaky radiators because the cheap plastic tanks either become loose where they join the aluminum body, or they crack/rub through. Check for coolant smell, level, and quality. The rest is pretty much like any other GM truck.
Good luck.
Old Dec 15, 2022 | 06:04 AM
Broken Halo's Avatar
I should have posted this thread on YouTube.....more than a quarter million views! So, how much are you paying me Doc?
Old Dec 15, 2022 | 10:52 AM
You get HF credit, props, kudos, at-a-boys, thanks, fame, admiration, adulation, and possibly a happy meal coupon.
Old Dec 15, 2022 | 12:34 PM
Harbor Freight has credit?
TNRed80
Oct 18, 2021 10:04 AM
FrankTheTank
Jul 1, 2021 02:45 PM
Treina
Apr 12, 2017 10:43 AM
Sfasddsf
Jun 6, 2016 08:09 AM
Ghostrider
Jul 8, 2008 03:22 PM
