Lighting problem
Old Jul 18, 2022 | 11:28 PM
Justme022786's Avatar
Default Lighting problem
Hey guys was hoping someone would know the answer to this. I just put the 7inch led lights on my H3 and somehow my high beams turn on low beams and low beams turn on high beams what did I do wrong?
Old Jul 19, 2022 | 09:21 AM
Welcome to HF.
Made your connections backwards?
Old Jul 19, 2022 | 09:29 AM
Originally Posted by Justme022786
Hey guys ... what did I do wrong?
Uhhhh, Ummmmm, DUH! Sounds like you wired the lights incorrectly.
Old Jul 19, 2022 | 09:41 AM
NMH3's Avatar
Did you use an adapter harness to switch the high/low polarity? Most LEDs use a common ground and switch the positive side input to go between high and low beam. The H3 wiring does the opposite and switches the ground side. An adapter harness with a relay is required to swap the polarity. They can be picked up in Amazon for not too much.
Detailed video here about converting to LEDSs
https://m.youtube.com/watch?v=SKi2cz2h6lE
Old Jul 19, 2022 | 10:04 AM
The wiring harness only goes on one way.
Old Jul 19, 2022 | 06:18 PM
Post pics of the connector contacts/wires. It appears China reversed wires to the connector. Seen it many times over the years.
H1Japan
Hummer H1
Aug 26, 2018 08:03 AM
Savdog01
Dec 25, 2007 10:02 AM
Ripskip
18
Nov 28, 2007 09:11 PM
HumV
Sep 27, 2007 08:09 PM
danist
Sep 4, 2006 04:05 PM
