Light mounts for OEM brush guard
Old 07-24-2014, 10:11 PM
bearcsa's Avatar
Default Light mounts for OEM brush guard
Help! can not find any that fit. the diameter of the bar is 1.3" No one makes that size. I bought the PIAA mount that was advertised to fit 1.25 to 1.5 bUt it is sized at 1.5 " and will not work. It even says 1.5" on box. I have no idea why it is advertised for 1.25-1.5!
Old 07-24-2014, 10:23 PM
Happy Hummer's Avatar
Use a spacer material such as plastic or rubber.
Chris
Old 07-24-2014, 11:37 PM
I bought these off of Ebay and they fit my 1.25" very well. If you look the spacer material inside allows it to be used on the 1.25" & remove the spacer and it will work on the 1.50".
Go to Home Depot, into the plumbing area ask for a sheet of rubber gasket material (less than $4) and cut your own strips. Easy fix.
Old 07-25-2014, 12:30 AM
bearcsa's Avatar
That looks like the one I have with a clear insert but it is not thick enough. looks like i will do the rubber gasket shim. I would think PIAA would have put differnt size inserts in their kit...oh well!
SafetyRick
04-15-2014 07:53 PM
reed75
07-03-2010 09:46 AM
Ron46
01-06-2010 11:06 PM
lucky19942001
05-03-2009 11:32 AM
joewcob3
06-04-2008 06:44 PM
Quick Reply: Light mounts for OEM brush guard
