Light bar in grill
Anyone tried it? I found a 28" wide x 2.75" high light bar which would fit almost perfectly recessed into the space currently occupied by the vented plastic grill beneath the word 'HUMMER'. I figure the radiator / cooling would probably be okay as the upper rad vents / holes are entirely unobstructed.
Thoughts?
Thoughts?
I bought a 28" curved unit, almost perfect in terms of the light bar shape matching the curve of the grill, all fits pretty snugly. Had to custom rig some mounts but it was worth it, looks superb. Need to install the switch / harness but holy ****, these things are bright! Pics to follow.
Here's how it worked out, pleased with it - you can see the light almost follows the curve of the body panel perfectly and is snug top to bottom.
28" curved light on eBay:
Eyourlife 144W 28'' Curved Spot Flood Work Light Bar Truck Jeep 4WD Ute SUV BL1 | eBay
Harness with relay:
Off Road LED Light Bar on Off Power Switch 40 Amp Relay Wiring Harness 1 Lamp | eBay
Switch:
Hummer H3 Off Road Lamp Switch Wire Harness P N 88963885 | eBay
Harness with relay:
Switch:
Harness with relay:
Switch:
Harness with relay:
Switch:
How about the light output? I'm really curious about that as well, and if you thought it might cause airflow to the radiator issues. Any advice is greatly appreciated.
Truck is being serviced so I can't take pics right now. I used the brackets that came with the light along with some stiff metal plates and used existing mounting points, then I used some more plates to push the light unit forward and into the grill space. Lock washers and Loctite seems to hold everything in place nicely.
I'm not too worried about the air flow as many others have done something similar, whether it be with a light bar or winch - and anyway, the upper and larger part of the grill / radiator is entirely unobstructed. The light shouldn't interfere in any way with the control box as it doesn't take up much space and is lower and forward, there's still 4 or so inches of clear space behind it.
Light output is, as Jeremy Clarkson put it - like a collapsed sun - I'll take some shots when I get the truck back.
cant wait to see the pics. i asked about airflow because i have the NFAB light bar with 4 KC's sitting in front of the grill and this set up would fall just below. while the KC's are bright, they are old school bright (dingy yellow). The wife won't let me take them off but is o.k. with me putting the 42" curved up top that i just recently acquired. She has no idea that I'm planning something for the lower grill just as you've done.
