Installed a Moroso Oil Catch Can
Old Aug 24, 2023 | 07:55 PM
You change oil every 3500/4000 miles?
Ever consider of using the OLM your truck has? It is 2023 now, the change your oil every 3500 miles is OLD School's OLD School. Like 25+ years out dated.
ENGINE OIL THAT BLACK>>>>> CHANGE ASAPx2
Btw,
My wife's '20 GMC already required 3 oil changes, and changed@-5%-0%. That makes 4 with the original oil when purchased new. Now @ 64% with only 19,602 miles:
Oil life monitors track climate, driving habits and other conditions. The algorithm calculates mileage, idle time, engine temperatures, trip times, engine loads, and ignition starts and stops.
Old Aug 25, 2023 | 05:11 PM
Justinh's Avatar
And what is the long term effect of extended oil change intervals? Many cars these days end up with stuck oil rings leading to excessive oil consumption. Maybe GM vehicles don't have this issue?
Old Aug 25, 2023 | 07:04 PM
Monitor your oil or else((((((((((blow-by))))))))))))> cylinder pressure leaking past the piston rings into the crankcase. Commonly, it starts as cylinder glazing or carbon forming in the top ring grooves, both of which allow cylinder leak down, and some oil burning. Oil burning produces further ring deposits, and more blow-by.
Old Aug 26, 2023 | 01:31 AM
Sam!'s Avatar
First off, Sorry Citiboy didnt mean to hijack your thread.
Correct, I am old and old habits are hard to break. even harder having other old vehicles and motorcycles that are all based on millage or abuse.
I installed the catch can and it is doing better than I expected. appears to catch sludge with condensation moisture. now the motor oil strays cleaner longer can visibly see it and now switched to Synthetic. I'll play it by ear on how many miles I let it go till. But I really want to do the Valve job on it and see what I find and how it improves.
Old Aug 26, 2023 | 07:46 PM
Did you try to remove the carbon buildup?
SeaFoamWorks!
bronxteck
Jul 23, 2022 06:37 AM
Hdog
Jun 26, 2022 05:13 PM
Zco
Apr 2, 2022 06:50 AM
Adamm
Hummer H1
Jan 25, 2022 01:31 PM
Stingray
Oct 16, 2014 09:07 PM
