Hummer h3 wipers intermittent
Old Jul 5, 2022 | 06:27 PM
dips's Avatar
Default Hummer h3 wipers intermittent
Hey guys,
Used to have a problem where I couldn't ever use wipers on high speed, didnt bother me since thats rarely needed, but lately now my wipers wont work at all.
I tried swapping the relay for wiper Hi/Low and Wiper on off (72 and 73) with a backup to isolate which one is bad, but it seems like theyre all bad, I go under the hood, play relay bingo for a bit, then theyll start working again, until they dont. Any ideas apart from just getting 3 new relays? It doesnt seem like a relay problem since all my swapping doesn't resolve the problem.
Old Jul 5, 2022 | 06:44 PM
Old Jul 6, 2022 | 12:12 PM
Just replaced a Buick Encore Wiper Motor over the weekend. If it is not a fuse or connection/harness issue, about 75% of the time it is the Wiper Motor, the other 25%......... the switch arm.
Old Jul 6, 2022 | 05:18 PM
Good point. Just find the signal loss! KOEO, WIPERS ON, wiggle/reseat/rotate:connectors/relays/switch. Warning: don't leave the wipers on a dry windshield or you will cause damage to the wiper motor/transmission. When you find the source of failure, open a can & clean contacts.
Old Jul 17, 2022 | 04:09 PM
dips's Avatar
got some new relays and problem seems to have resolved itself, my starter relay did go recently so maybe they all decided to
solved for now
thanks for the help though guys
-Dips
Old Jul 17, 2022 | 05:30 PM
solved for now
-Dips
All my '07 relays are oem! Inspect the fuse box:
mj44141
May 6, 2019 08:25 PM
Vinny713
Jan 23, 2015 12:59 PM
HumV
Nov 6, 2014 11:31 AM
steves05h2t
Jun 10, 2008 11:44 PM
MRDM1
Mar 10, 2008 10:01 AM
