Hummer H3 Rear Door Vent Seal?
Old Jun 28, 2023 | 08:13 AM
  #21
NMH3's Avatar
Buy yourself a rubber sheet: https://www.mcmaster.com/products/rubber-sheets/ Cut out a square the size of the vent. make some 3 sided cutouts for the flaps so they'll flex out when under pressure and close to keep bugs/dirt out when not under pressure. Project complete.
Perfect, thank you! Any suggestions for the right thickness and material for the sheet? Lots of choices.
Old Jun 28, 2023 | 02:17 PM
  #22
Broken Halo's Avatar
Just mic the old flap and get something equivalent. Instead of rubber get a Viton or Silicone sheet....more expensive but will hold up much better.
Old Jun 28, 2023 | 10:37 PM
  #23
Ken06H3's Avatar
Purchased one earlier this month at https://www.thepartsolution.com/
$24.78 Part 15209785 +10.09 Ship
One left in stock when I posted this
Old Sep 30, 2023 | 03:24 PM
  #24
superbeer's Avatar
Default Alternate part that works
For everybody looking for this part (15209785) I found an alternate part from Dodge that is nearly an exact match, just search for Mopar 68260545AA. The only thing is you need to pry off the outer vent portion of the old part that faces the spare tire carrier with a utility knife and glue it onto the new part. Now I can remove the rag I have stuffed into the hole. I found this image from some russian dude who manually repaired his (pretty good job)
Old Oct 1, 2023 | 04:25 PM
  #25
Justinh's Avatar
Thanks for sharing that info.
Old Nov 6, 2023 | 11:21 PM
  #26
KU1525's Avatar
Just wanted to give a shoutout to @superbeer for the tip about the rear door vent. I just finished doing this and can confirm that everything works as described. The structural components of my vent were fine, but the rubber seal which held it against the door was 75% gone which caused it to rattle around when I accelerated mainly. The plastic piece that you pry off the old unit is basically a perfect fit when you glue it to the new vent. I added some photos of the finished product for reference below.
I have a 2008 and went with the Quarter Panel Exhauster - Mopar (68260545AA) for $18 (part + shipping). Ordered from them Thursday evening at 6:00 and the part was in my mailbox this afternoon (Monday).
Dave73
Jul 7, 2020 09:50 AM
rubhed
Private 'Wanted' Classifieds
Apr 14, 2020 12:53 PM
SquareD
Nov 29, 2016 11:55 AM
DirtyH3
Jul 15, 2015 12:50 PM
markass
Mar 30, 2012 07:31 AM
