Hummer H3 Rear Door Vent Seal?
Old Jun 19, 2023 | 01:46 PM
Knightblade's Avatar
Smile Hummer H3 Rear Door Vent Seal?
Hello, hello! Long time no post.
So, I've got a bit of a conundrum. I've got a 2007 Hummer H3. It, like all the other H3's has that de-pressurizing vent in the back door under the spare tire carrier. Now I'm not looking to block it off, or replace it or put a light in it. No, my problem is a bit different.
The vent itself is still in place, still works, etc... The weather-stripping/seal/whateveryoucallit, the black rubber stuff that keeps it settled in the door, rotted out and fell apart, so now the vent just kind of bobbles around. when I'm going over bumps. Thankfully the 'cure' so far has just been 'crank the stereo', lol. SO! The big question is, does -anyone- have a part number, or suggestion to put the thing back in place so it -doesn't- bobble around? I've been toying with the idea of black silicone or maybe gorilla double-sided tape on the inside of the door, but I'd rather try to go OE if I could, thus far I haven't found a part number for that seal-strip stuff on any GM OE parts website, rockauto, or anywhere else.
Any help would be greatly appreciated!
Thanks!
2007 Hummer H3 rear door vent. Pardon how dirty she is, I need to give her a bath.
Old Jun 19, 2023 | 03:20 PM
I installed a led light included seal to stop the water from getting in the rear door. I found my oem jack unused/rusted and all other contents in the cargo door were wet. Been dry inside since my project found here>Giving some attention to the rear
Old Jun 19, 2023 | 04:16 PM
some dense foam weather seal strip tape from a local hardware store? they come in different widths. used for doors and windows / ac units
Old Jun 20, 2023 | 08:17 AM
I believe he is talking about the flappers inside the rear deflector purge vent. The rubber flappers are not a "part" by themselves, you have to buy the whole unit. GM 15209785 if you can find one.
Old Jun 20, 2023 | 08:50 AM
Old Jun 20, 2023 | 11:23 AM
Disel's Avatar
https://youtu.be/IRHwEqtfaOc
how does ventilation work?
Old Jun 20, 2023 | 03:42 PM
650Hawk's Avatar
Cool
It doesn't
Old Jun 20, 2023 | 03:46 PM
HVAC Air Inlet > Air Inlet Duct >Air Distributor Case >HVAC Unit Case
Old Jun 20, 2023 | 09:52 PM
Revmatch's Avatar
That device is a pressure relief valve for the interior of the vehicle. Its purpose is to let air escape when doors are closed thereby reducing door closing efforts. Without it the doors would tend to bounce off the seals unless slammed due to the resistance created by air being compressed inside the vehicle.
Old Jun 21, 2023 | 09:05 AM
It is also to allow air to vent OUT when you run the fan which actually pressurizes the cabin when windows are closed.
