Hummer H3 no heater
Old Dec 4, 2023 | 06:48 PM
AZ_H3's Avatar
Default Hummer H3 no heater
Hello all,
My H3 only blows full cold and will not provide heat. I've searched so I have a good idea of the components that make up the heating system.
1. Coolant system is full and topped off. Both heater lines feel hot to the touch.
2. Thermostat appears to be functioning. Vehicle temperature is normal around the halfway mark.
3. Performed A/C calibration test. System cycled through all the different positions but still no heat.
4. Removed heater blower fuse and it looks fine. Nothing burnt.
5. Looked under the dash and only the top actuator moves when changing the different airflow positions. Bottom two actuators do not move with any of the A/C dials are adjusted.
I find it hard to believe that both actuators would go bad at the same time—is there something in the system that ties these two actuators together that I could check? Or should I just proceed to changing these both out?
Thanks for any assistance!
Old Dec 5, 2023 | 09:19 AM
There are 4 actuators. I am not 10% sure which does what. Hunnerz should be around soon to clarify.
Video for you to check out also.
https://youtu.be/m2ve2ixV9GE
Old Dec 5, 2023 | 04:23 PM
Both lowers (#30) control temp between heater/evaporator cores.
4 ACTUATOR, AIR INL VLV 10397102
30 (x2) ACTUATOR, TEMP VLV 10397365
32 ACTUATOR, MODE VLV 10397102
Scotts H3 Hummer
Apr 10, 2022 02:47 PM
Dtnations
Jan 10, 2022 02:21 PM
bigdog100
Jan 3, 2022 02:14 PM
ShackMan
Feb 7, 2020 03:09 PM
joenuzz
Dec 5, 2011 11:33 PM
