Cannot get heater to blow hot.
Old Jan 23, 2012 | 05:56 PM
bigdog100's Avatar
Default Cannot get heater to blow hot.
This is a repost. The blower works and AC works. However when I turn **** to heat it still blows cold unless I do factory reset and sometime it will get hot. Any help would be appreciated.
Old Jan 24, 2012 | 07:39 AM
RKSmith163's Avatar
First I would check to see if the radiator has enough fluid in it. If so, feel the heater hoses going into your firewall to see if they are getting hot. Other items to look for would be the heater control valve, or thermostat.
Old Jan 24, 2012 | 08:41 AM
lcurle's Avatar
find the heater hoses, there should be two of them, one for inlet one for outlet. Both should be warm/hot. If only one is hot and the other is cold, then it is your heater core that is the issue.
Old Jan 24, 2012 | 03:56 PM
bigdog100's Avatar
The heat comes on somtimes and when it does I have to do the factory reset then I hear a few thuds under dash like a flap is closing then heat blows. I am assuming the heater core is good and yes radiator is full.
Old Jan 25, 2012 | 07:41 AM
RKSmith163's Avatar
Try this Actuator Calibration Procedure out of the Service Manual. If that doesn't work, your actuators may be faulty.
1. Turn ON the ignition with the engine OFF.
2. Turn the Temperature dial all the way to the right.
3. Turn the blower control dial all the way to the right.
4. Turn the mode position dial all the way to the left.
5. Simultaneously press and hold the A/C and Defrost buttons until the LED's start to flash.
6. Once the LED's stop flashing, calibration is complete.
Old Jan 25, 2012 | 09:47 AM
bigdog100's Avatar
Yes i have done that and it is the only way I can get the heat to work. How would I replace the actuator for cold to hot?
Old Feb 11, 2012 | 12:45 PM
bigdog100's Avatar
The actuator has a stripped worm gear but still functions however the female end is kinda stripped also so I am not sure who is not working.
Old Feb 11, 2012 | 12:53 PM
drtom's Avatar
Banned
ahhh, if the parts are worn out id guess u need to toss them and put new ones in huh
Old Feb 11, 2012 | 02:16 PM
bigdog100's Avatar
Well the female end is a huge job, going to try new actuator first just not sure why felmale end is striped also
Old Oct 18, 2012 | 01:52 PM
samannsc's Avatar
RKSmith163 you r a lifesaver works great,ac/heat works fine now,thanks sam
