High Mileage
Old 07-27-2011, 02:48 AM
Songman's Avatar
There are several threads about the top plastic radiator tanks cracking. It is a design flaw. Some people try to get the dealer to replace them. I opted to just have mine rebuilt locally with new tanks.
Here is the thread with the most info...
https://www.hummerforums.com/forum/h...-leaked-21184/
Here is a picture someone posted showing the crack everyone is getting. Not all are as pronounced as this one. I was chasing a mystery leak for months because the crack was too small to see.
Old 07-27-2011, 07:50 PM
NJTEX's Avatar
Check to make sure the trailer wiring isn't chafing where it's tied down to the frame under the rear hatch. A few people have had to replace the body control module because of a short in this area.
Old 07-27-2011, 10:05 PM
jjhickey3's Avatar
I just turned 140,000 on mine. I replace the raditor at about 98,000. No other problems.
Old 07-28-2011, 10:39 AM
Broken Halo's Avatar
Originally Posted by clan0013
I'm at about the 80K mile mark on my 2006 H3 (has the Luxury/Adventure combo with manual transmission). I bought it 4 years ago with 10K on it. I've had to replace the hood release cable, rear window washer fluid pump, windshield, brakes and tires. Have not had and radiator or head gasket problems.
About two weeks ago it started running rough at certain speeds/gears randomly. Yesterday evening it got a lot worse. On my way home in traffic all of a sudden I could only get it to go about 2 - 3 mph no matter how much I pushed on the pedal and it was real jerky. I had it towed to my local Hummer/Chevy dealership last night.
I'm thinking it's a Catalytic Converter or Oxygen Sensor or Fuel Pump issue. I haven't heard back from the dealership, so I'm not sure what the official diagnosis is yet. Hopefully the cost of repair wont be too high...not that I have any choice, it's my only wheels so I'll have to pay whatever the damage is.
Anyone else out there have a oxygen, fuel, or emission problems in the past?
Fuel Pump could be a possibility, but I doubt it would be your cat, and it wouldn't be your O2 sensor. You didn't say if your 'Check Engine' light came on or not, which is an indicator of an emission control function failure. If your O2 sensor were bad, your system would go into 'Open Loop', and would still be drivable, but with a richer fuel mixture.
Old 07-28-2011, 03:21 PM
tomsbeast87's Avatar
yea with no lights on the dash i would go with the fuel pump.
Old 08-04-2011, 01:19 PM
drtom's Avatar
Banned
Ha! OK, so I don't know how this happened, but it got put into 4x4 low and that is why it was not letting me go more than 2 -3 mph all of a sudden. This seemed to be an unrelated event to my vibration I have been experiencing though.
?, you didnt notice the engine screaming,racing at 4000-6000 rpm? i hope you didnt drive a long way!!,on the street, it stresses the drive train,u joints etc!
Old 08-09-2011, 09:06 PM
bheff's Avatar
'07 adventure package with 82k. Just replaced the radiator (transmission cooler cracked), and transmission. Other than that I had to replace the driver side window and lock switch.
Old 08-10-2011, 09:02 AM
HighmileageH3's Avatar
Default 2006 H3 Adventure pkg with 5 speed manual
just passed 156,700 miles. I purchased the truck new and love it. Regular maintenance across the board. Only serious problem was the "core heater element." 160 part and 800 in labor. They had to take out the entire dash and I didn't want to save a few dollars on labor and risk having a vibrating dash board.
Old 12-31-2011, 04:50 PM
Macrosfear's Avatar
I just got my '07 with 63,300 and it ran pretty good. Changed oil, spark plugs and air filter. It now runs way better. Experienced moderate vibration, dealer diagnosed it as broken motor mounts(both sides). Also, my front windshield leaks water down the center(minor issue), plus I've noticed that the temp gauge never seems to reach 1/2 way, so I'm suspecting that my thermostat might be stuck open.
Old 12-31-2011, 06:33 PM
drtom's Avatar
Banned
TEMP NEEDLE should be just under the half mark,no much.like a needle thick.
mine rarely moves once heated up. i never saw it above half,even in july
Quick Reply: High Mileage
