Hi everyone just joined and have a question on a steering issue?
Old Aug 13, 2024 | 05:48 PM
Bigguy214's Avatar
Default Hi everyone just joined and have a question on a steering issue?
Hello everyone just picked up a 2006 H3 and when driving the steering wheel seems to bind up a little and I just turn it a little to the left or right it frees up.Sounds like plastic is rubbing together.I tried doing a search and didn’t see anything.Anyone have this problem before and might know a fix.It has 160k on it and has been sitting for awhile.I looked under the steering column and looks like there is a bushing there I was wondering if that might be it?Any thoughts would helpful and thanks for any replies.
Old Aug 14, 2024 | 05:58 AM
Could be the "rag joint" is deteriorating or intermediate steering shaft knuckle is worn/rusted.
Both are replaceable parts.
Old Aug 14, 2024 | 09:11 AM
Welcome to HF.
Look under the hood at the condition of the steering shaft U Joint/knuckle. They rust in the Great Salty North and can click or bind enough to feel that. If rusty, you can test that by lubing the joint with a penetrating white lithium grease or a multi-purpose lube to see if that changes the feel. If bad enough, might need replacing.
Old Aug 14, 2024 | 09:35 AM
could be the lower coulumn bearing if it sounds like plastic.
Hmmm...er
Sep 12, 2017 05:01 AM
Sooner1
Nov 13, 2016 07:26 AM
Oprime2014
Oct 3, 2014 05:39 PM
gcompton
Jun 5, 2011 09:43 AM
eight_bit_micro
Oct 12, 2008 08:53 PM
