HELP - Hummer won't move in any gear.
Old Jan 8, 2017 | 11:56 AM
slateblueh3's Avatar
Default HELP - Hummer won't move in any gear.
Yesterday while driving down the highway at 110km/h my car revved up like it was in neutral. I pulled over and then discovered the car wouldn't drive in any gear. There was no noise when this happened. Tow truck came and the car can roll while in park. Transfer case issue? Any known specifics on what can cause this? Any recommended fixes?
The H3 was warmed up but temp was close to -35 celsius.
2006 H3 Lux
Thanks.
Old Jan 9, 2017 | 07:55 AM
sycraft's Avatar
probably transmission, input shaft could have sheared. Transfer case only transfer power to the front wheels, so rear wheels would still drive if it failed.
Old Jan 10, 2017 | 06:29 PM
650Hawk's Avatar
Not true; both front and rear driveshaft are driven out of the transfer case.
Bad Encoder motor could've shifted the transfer case to neutral; try cycling the 4wd hi/4wd hi-lock/4wd lo-lock buttons a few times.
Old Jan 11, 2017 | 11:01 AM
Or............... your trans is toast.
Old Jan 16, 2017 | 11:15 AM
Zero83's Avatar
I had a H2 in my shop one time that the shifter linkage on the trans was disconnected. The owner told me about it once we told him there was a problem with his truck, he told me " Yea, it dones that from time to time, just toss another zip tie on there for me"
LOL,
Old Nov 23, 2019 | 11:01 PM
Dee's Avatar
Dee
2006 H3 Lux
Thanks.
​​​​​​​I'm having similar problem. Did you find out how to fix it?
danaw
Jun 4, 2022 01:17 AM
omarluna2
Nov 11, 2014 09:01 AM
elkgrunt
Mar 29, 2014 06:27 AM
JCsh2
Mar 12, 2013 03:46 PM
Mike Sandelier
Nov 21, 2012 10:38 PM
