Heater Core inlet hose
Old Jan 2, 2020 | 05:09 PM
Infantry11b248h's Avatar
https://www.grainger.com/product/45R...!500456302764!
Is this it?
Also, Any idea what Diameter i'll need?
Old Jan 2, 2020 | 05:19 PM
the gates elbow says .75" but double check it when you get the old one off.
Old Jan 2, 2020 | 05:25 PM
Yes,measure your hose should be 1/2"-5/8". Go to your local auto parts store, and they will measure your hoses and give you the proper clamps(#10-#12).
Old Jan 2, 2020 | 05:32 PM
That's O.D. on 1/2" hose.
Old Jan 2, 2020 | 05:44 PM
Yes, you can cut the band clamps and replace the hose, however make sure to properly secure the hose at both ends with gear clamps and pressure check.
can I cut these off of the metal piping somehow? Perhaps side cutters?
Old Jan 2, 2020 | 06:28 PM
I use a cutoff tool, yet you can use a sawzall or hacksaw.... just score it enough to pull the band clamp with your side cutters, peel it off. Don't worry about damaging the hose, but DO NOT CUT THE TUBE! Be patient and careful how deep you cut. When you get the new hose on, slide it as far as you can, then install the clamp in a flat spot (not on the flare) on the tube, then tighten secure, and pressure check the system before you refill or drive. GL
Old Jan 2, 2020 | 06:52 PM
I'll try that tomorrow. Thanks a ton for yer info. We've been waiting 3 weeks now for our order from the stealership.
Old Jan 2, 2020 | 06:58 PM
Diy, and save yourself $. I forgot to add, the flare in front of the band clamp is the tube. Cut and peel that band clamp without damaging the tube and your good to go. GL
x2nervisx
Mar 29, 2020 08:37 AM
sinful7
May 17, 2016 10:28 AM
RickStang
Nov 18, 2011 06:56 PM
yellow7
May 8, 2011 04:16 PM
fishaholic
Mar 27, 2007 01:27 PM
